1986 Dodge 600 power windows not working
139,000 MILES • 4 CYL • FWD • AUTOMATIC
DODGE600FAN
I just bought this car. Guy IO got it from said he replaced 2 of the pwer windows motors, but after that all windows stopped working at the same time. He told me its probably the fuse. Seems reasonable. I dont have the owners manual and the fusebox does not specifically mention which fuse is for the windows. Can you advise which fuse is for the power windows? (I'd rather not try every single one).
Thanks.
May 5, 2010 at 2:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Check out fuse #3 (30 amp circuit breaker) in the fuse block located to the left of the steering column, behind the instrument panel lower trim. If the fuse is not the issue then there could be a faulty window switch or bad wiring to one of the switches.
May 5, 2010 at 5:22 AM
