Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Taurus
Suspension
Ball Joint
Replace/Remove
Do we need to remove the axle to replace front ball joints
2004 FORD TAURUS
10,000 MILES • 6 CYL • FWD • AUTOMATIC
DLYNCH5
MEMBER
1 POST
Front end is shot, replacing both front ball joints, have the parts so far, but need to know if this can be done without removing the front axle?
Feb 5, 2017 at 4:25 AM
JIS001
Experienced Mechanic
If you plan on trying to do the repair on the vehicle then yes you do. But if you are removing the control arm for the repair then no.
Feb 5, 2017 at 5:35 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
