Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Kia
Sedona
Engine
Camshaft
Timing
Do the timing marks have to line up?
2004 KIA SEDONA
94,000 MILES • V6 • FWD • AUTOMATIC
CGEORGEPLASTER
MEMBER
1 POST
The check engine light code reads camshaft position sensor. I opened up the sensor and the timing marks are all off. Is that normal?
Feb 16, 2016 at 1:36 AM
CGEORGEPLASTER
MEMBER
1 POST
Here are some pictures that should help you.
Images (Click to enlarge)
Feb 16, 2016 at 1:41 AM
JOHNNYT73
Experienced Mechanic
You have have to se the crankshaft to top dead center. When you do that then all the timing marks should line up.
Feb 16, 2016 at 1:44 AM
Have you replaced the CMS? does the engine run okay?
Mar 7, 2016 at 5:36 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
