A/C compressor not turning on
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
FRED WINDRICK
The air compressor for the A/C will not come on. Does the A/C have a fuse?
Sep 17, 2018 at 7:33 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Quick question first. When was the last time refrigerant was added or A/C system serviced? The A/C system has a built in cut-off switch so that when a low level of refrigerant is detected it shuts off the system to prevent damage. Yes, the system is fused and also has a relay. I have attached a tutorial for you to view. Hope this helps and feel free to ask any questions.Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Sep 17, 2018 at 8:20 AM
FRED WINDRICK
Thank you. After the checking the Freon with a gauge it was low. Charged it it works fine. Thanks.
Sep 17, 2018 at 9:14 AM
DANNY L
  • 5,648 POSTS
You are welcome!
Thanks again for using 2CarPros.
Danny-
Sep 17, 2018 at 9:30 AM
