Do I need a different spindle and knuckle
117,000 MILES • 1.7L • 4 CYL • 2WD • AUTOMATIC
ABEEZYMC
I changed my factory wheels to 17 inch Acura rims. My car then had a humming noise I assumed was from the low profile tires. It got worse with time and now is almost unbearable. I have come to the conclusion thaghi need to replace the bearing but can't without a machine to press it in so I plan to replace the whole spindle and knuckle. Do I go with the factory one just like it came with or do I need a different one? And do I change both fronts or can I change just the one?
Feb 11, 2020 at 11:23 AM
STEVE W.
  • 15,418 POSTS
You can change that bearing out with nothing but a small bearing press and a slide hammer. Both of those are usually available as loaner tools from parts stores.
This is a video that covers the same style bearing on a different car to show the method:
https://www.youtube.com/watch?v=2IcUFGM0wWk
Feb 11, 2020 at 11:36 AM
ABEEZYMC
Are the components suitable for 17 inch wheels?
Feb 11, 2020 at 12:29 PM
STEVE W.
  • 15,418 POSTS
They use the same parts across the entire line. The biggest issue on bearing wear when it comes to rims is the offset. The more offset the more pressure is on the bearings. As long as the offset is kept in a range close to original the bearings won't be a problem.
Feb 11, 2020 at 12:46 PM
ABEEZYMC
Thank you very much!
Feb 11, 2020 at 12:47 PM
STEVE W.
  • 15,418 POSTS
No problem. Just buy the better bearings not the cheapest one. Thank you for using 2CarPros.
Feb 11, 2020 at 12:50 PM
