Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Subaru
Tribeca
Drivetrain
Drive Shaft
Center Support
Replacing the center bearing
2006 SUBARU TRIBECA
197,100 MILES • 3.0L • 3 CYL • 4WD • AUTOMATIC
LINDA TURNER2
MEMBER
1 POST
The center bearing went out. Do I have to take the whole driveshaft off to change the center bearing supp.
Mar 10, 2022 at 12:50 AM
Experienced Mechanic
If you are replacing the bearing/support, yes it needs to be removed.
If you look below, I provided the directions for the removal and replacement of the drive shaft.
Images (Click to enlarge)
Mar 11, 2022 at 5:15 AM
Add image or video
Ask a new question
