Do front CV axles need replacement or not?
147,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
REZA HASS
A few days ago, I had a pre-purchase inspection done by a Toyota dealership on my car. They mentioned that the battery failed the performance test and identified seepage from the front axles, recommending replacement for both the battery and axles.
However, I later had the battery tested by Canadian Tire, which confirmed that it is in good condition with an average remaining life of 51 months. Additionally, a certified mechanic inspected the axles and found no signs of leakage, cracks, or any other damage, stating that the axles are in good condition.
I would appreciate a second opinion on the axles, as the potential buyer is concerned and insists on knowing why the dealership recommended replacement.
Oct 6, 2024 at 10:30 PM
  • 55,694 POSTS
If you are not having vibration issues under acceleration, I would not do the CV axles, if the grease is just leaking slightly, I would not worry about it.
Oct 7, 2024 at 3:49 AM
