Do any “liquid mechanic” preparations work
111,000 MILES • 3.4L • 6 CYL • 4WD • AUTOMATIC
VSSOUTLET
  • 57 POSTS
This is a general question rather than a question for my car. You walk into any auto parts store, and you find dozens of bottles claiming to fix anything from bad gaskets to engine sludge to A/C leaks; as well as those that claim to improve performance and gas mileage. This is a multi-billion dollar industry. As mechanics, how would you rate the claims of these products? Are there any that you do recommend?
Sep 17, 2018 at 4:15 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Most of those "Mechanic in a Can" products are a joke. Whenever it states to be a stop leak all the product is designed to do is swell up the seals to stop the leak. After enough time the seals fail and you are then forced to actually fix the problem. As far as what I use is "Seafoam" as an additive to the gas tank when treating years old gas trying to start a car and not wanting to drop the fuel tank. Lucas brand is also a good additive as a last ditch effort to keep a car hanging on. Hope this helps and thanks for using 2CarPros.
Danny-
Sep 17, 2018 at 4:24 PM
VSSOUTLET
  • 57 POSTS
Thanks Danny. I suppose it is hope and desperation that sells these products.
Sep 17, 2018 at 5:15 PM
DANNY L
  • 5,648 POSTS
Absolutely! Or a low cost solution to bide time until time/money to really fix problem. Thanks again for using 2CarPros.
Danny-
Sep 18, 2018 at 5:10 AM
