No fire to cylinders five and six
200,000 MILES • 4.9L • 6 CYL • 4WD • MANUAL
BILL COOK4
i am getting fire on my cap to cylinder number five and none on number six.
Feb 23, 2018 at 6:29 AM
CJ MEDEVAC
  • 11,000 POSTS
Is your firing order correct?
How are you testing for spark?
Have you swapped number six plug wire with another (like number one)?
The Medic
Feb 23, 2018 at 7:52 AM
STEVE W.
  • 15,414 POSTS
Pull the cap and see if the contact inside the cap is corroded away.
When was the last time it got a cap/rotor/wires/plugs?
Feb 23, 2018 at 9:06 AM
HARRY P
  • 2,292 POSTS
Also, a hairline crack on the distributor cap could cause this. I had one do the same to me. I chased it all around the ignition system, replacing the plug, the wire, cleaning the cap contacts, and so on. Finally I put a new cap on. When I got the old one into the light, I could see the crack in it leading from the number one cylinder (the one that was not firing) towards the center contact. Presto change-o, it purred like a kitten again when I fired it up. So, get a new cap.
Feb 23, 2018 at 11:59 AM
BILL COOK4
two new caps no fire on six all five others okay.
Feb 24, 2018 at 12:54 AM
CJ MEDEVAC
  • 11,000 POSTS
No answers for my questions?
The Medic
Feb 24, 2018 at 4:44 AM
STEVE W.
  • 15,414 POSTS
Okay, you had two new caps and get spark at all towers except number six?
How and where did you test for the lack of spark? End of the wires? At the plug? With a spark plug or spark tester?
Feb 25, 2018 at 10:46 AM
