distributor timing
220,000 MILES • V8 • 2WD • AUTOMATIC
TIFFANY FAYE
I need to know how to put the car back in time after changing my pick up coil.
Jan 22, 2017 at 11:12 PM
LOU P
  • 118 POSTS
Hello, you need to set the number one cylinder to top dead center, this can be done by rotating the engine and either using a 1/4" long extension to tell when the one piston is top dead or a dowel (carefully so it do not crack off) and then you need to set the rotor to point at the distributor cap one wire terminal, I will upload a photo of where number one wire and terminal of the cap should be located. this will get you in the right area.
Jan 23, 2017 at 1:17 AM
LOU P
  • 118 POSTS
Here is the firing order and the location of the number one wire. hope this helps.
Jan 23, 2017 at 1:22 AM
