Checking the cap and rotor I noticed that the distributor was loose in the engine
052361
MEMBER
1988 DODGE LANCER
2.5L
4 CYL
FWD
AUTOMATIC
200,000 MILES
While checking the cap and rotor I noticed that the distributor was loose in the engine. It moved side to side and front to back.
I do not remember it being that loose the one time I had it removed. Do I have a bad distributor, or should it move like this when I remove the hold down bolt?
Monday, October 3rd, 2016 AT 6:45 AM
HMAC300
MECHANIC
If the hold down bolt is removed it will move all over, if its not then the distributor may be broken like the housing.
