distributor
150,000 MILES
ANGELEYES19940
distributor details or anything that will help us figure out why the gears are not turning at all without no fire getting to the distributor. have taken it apart and they are not turning r firing. van lost all power and just shut off
May 29, 2013 at 5:45 AM
CARADIODOC
  • 34,414 POSTS
If the distributor isn't turning the camshaft isn't either. The logical conclusion is the timing belt is broken. If your engine is an interference engine and the timing belt broke you'll need a valve job too.
May 29, 2013 at 3:49 PM
