Car starts and idles fine but breaks up and cuts out above 3,000 RPMs?
220,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
MARCS1024
The car listed above is a coupe with a G23vtec swap. Chipped p28 ECU. New dizzy. New TPS.
Jul 25, 2023 at 7:45 AM
  • 55,770 POSTS
Any codes? here is a guide to help you run the codes, but it sounds like the ignition distributor is bad.
Check out the images (below). Please let us know how it goes
Jul 27, 2023 at 6:31 AM
