Hi, i pulled my distributor to pieces a while ago. I put back together and motor only just fires, now inside the distributor the wiring does it matter which way the wires go for instance which is positive on coil? I have a black/white wire which has 12-volts and green wire to coil which way round do the go then we have the camshaft shat sensor or hall sensor optocoupler with two wires blue and green. Which way do they go? please if anyone has a picture or diagram a simple one of inside distributor be so good.
May 11, 2023 at 1:28 AM
