Truck was running fine changed the distributor and plugs and wires all new now won't start.
May 24, 2023 at 4:54 AM
✓Experienced Mechanic
It sounds like when you installed the distributor you got it a tooth off which will make the engine not start. Here is how the unit is installed in the images below. This guide may help as well:
