Distributer pick up replacement
125,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
JOANN BONKA
Need to know how to take off the metal plate which is just above the pickups on the distributor.
Jul 31, 2016 at 7:58 AM
HMAC300
  • 48,601 POSTS
the distributor has to be removed from engine then gear removed to pull up shaft to remove it. see pictures.
Jul 31, 2016 at 8:54 AM
JOANN BONKA
Thank you so very much. I just needed the most simple form of an answer.
Jul 31, 2016 at 9:37 AM
  • 55,694 POSTS
Nice work Hmac300
Please use 2CarPros anytime
Best, Ken
Aug 10, 2016 at 4:25 AM
