Distributor swap
200,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
KEITH TAYLOR
I want to know if it is posible to replace a 1997 TBI distributor with a vacuum advance HEI distributer and still use the fuel injection system?
Jun 16, 2020 at 11:24 AM
Good morning,
No, it is not.
In 1997, the distributor is actually a camshaft position sensor and the ECM depends on a signal from that sensor for timing the engine and controlling fuel mapping.
What is the issue that makes you want to change?
Jun 16, 2020 at 8:31 PM
