distributor
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
TINA EDWARDS
How do you test continuity in distributor?
May 13, 2016 at 10:45 AM
CARADIODOC
  • 34,414 POSTS
Replace it to see if the problem is solved. There is nothing you can test inside it. Older cars often had a simple two-wire pickup coil where you could measure if it had a broken wire. Normal resistance was around 500 to 850 ohms. Almost everything today uses a three-wire "crankshaft position sensor" and a three-wire "camshaft position sensor". The cam sensor can be in the distributor. If that signal drops out while driving, on a car as new as yours the engine might continue running until you turn it off, but it usually will not restart. By that time a diagnostic fault code will be set in the Engine Computer related to that circuit.
May 13, 2016 at 10:58 AM
