distortion of rotors
200,000 MILES
GETAHUN
what is the main cause for distortion of disc rotors
Feb 25, 2016 at 3:26 AM
HMAC300
  • 48,601 POSTS
actually a couple crappy rotors as well as to much heat. all rotors will distort somewhat over time and can be resurfaced if they are thick enough. some are not
Feb 25, 2016 at 4:01 AM
WRENCHTECH
  • 20,760 POSTS
To add to HMAC300's answer. If you get them real hot like coming down an off ramp from high speed and you happen to hit a puddle, you will pretty much instantly destroy them. High heat and rapid cooling is the issue.
Feb 25, 2016 at 7:17 AM
