Disconnecting batteries to work on vehicle
135,000 MILES • 6.0L • V8 • TURBO • RWD • AUTOMATIC
BRYONWAR
I am replacing the starter solenoid and need to disconnect the batteries there are two on the rear passenger side and was wondering if there was a way to disconnect the power without having to lower both batteries. The vehicle is a 2006 ford e350 SD diesel with the 6.0 Thanks
May 18, 2015 at 10:39 AM
HMAC300
  • 48,601 POSTS
you only need to disconnect the negative battery cable on frame it connects both batteries...see pic
May 18, 2015 at 11:08 PM
