Do I need to disconnect my battery if I leave my car parked for two weeks in the cold
15,000 MILES • 4WD • MANUAL
KCHURCH
I am leaving for two weeks, but my car is going to be staying unused in a garage (downtown) in Nebraska. Do I need to disconnect my battery? I left it for a month before and it needed jumped/battery replaced.
Dec 14, 2016 at 11:52 PM
HMAC300
  • 48,601 POSTS
it would be a good idea. you would have to reset some things after picking up, but it still should be charged. most it would need is a jump.
Dec 15, 2016 at 1:57 AM
STEVE W.
  • 15,420 POSTS
With all of the items on a modern vehicle that draw power even when they are shut off I keep anything parked more than a couple days on a battery tender. If the garage has power that would be the best option. If not then disconnecting the battery will work, just be prepared for the car to run a bit different when you come back as the computer will need to re-learn a few control parameters.
Dec 15, 2016 at 6:14 AM
RENEE L
  • 1,260 POSTS
Great team work HMAC300 and STEVE W.
Dec 15, 2016 at 9:26 AM
