disassembling the steering column
LWINDLE
How do you get the housing for the ignition key off of the column. I took out the three screws - do you know how it slides off? It is a tilt wheel column on a 77 el camino. Do i need to take the ignition switch off so the rod can slide out?
Apr 18, 2013 at 3:52 AM
DOCFIXIT
  • 18,828 POSTS
Unbolt lower column the cover will come off
Apr 18, 2013 at 3:58 AM
