Hello again.
Okay, just making sure. Below I've attached pictures of the wiring diagram showing which wires control the circuit. Two wires go to the BCM (body control module) two wires go to the headlight assemblies and one wire goes to the under hood junction box.They all tie into the multi-function switch (turn signal lever). Here is a tutorial showing how to check wiring:
Hope this helps and feel free to ask any questions if needed.Thanks for using 2CarPros.
Danny-
Images (Click to enlarge)
Dec 31, 2018 at 4:41 PM
