Diminished power
144,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
TWYLA1958
Warmed car up and drove about three blocks. Check engine light came on and the car started shaking and would barely accelerate. Drove back home the three blocks and speed would not go over thirty mph and car continued to shake.
Dec 8, 2017 at 12:34 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
The check engine light came on because there is one or more trouble codes set in the computer memory. You should have those trouble codes read and then post them in here if you want then we will help you fix it.
Dec 8, 2017 at 12:42 AM
TWYLA1958
That is great but do you think it is okay to drive it if it is not overheating?
Dec 8, 2017 at 12:44 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
No, I would not drive it, unless it is to a shop or auto-parts store that can retrieve those codes or fix it and I would not drive more than just a few miles too.
You never know what it could be and if you have towing insurance you may even want to just have it towed.
Dec 8, 2017 at 12:56 AM
TWYLA1958
I only going to drive to auto parts store to have code pulled, about four miles round trip. But I will talk to my daughters boyfriend first since he is a former mechanic. Really miss my dad at these times who was the best mechanic in Oklahoma!
Dec 8, 2017 at 1:16 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Okay, let me know if I can be of further help when you get the codes.
Dec 8, 2017 at 1:34 AM
TWYLA1958
Sorry I did not email but I went home I took the car to parts store, it was running fine by this time. they ran a code and it pulled code P2101, it detected an unexpected voltage on the throttle actuator control motor circuit during the Comprehensive Component Monitor self-test. I have not had the problem again. Thank you for your help.
Dec 19, 2017 at 12:11 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are welcome.
Dec 19, 2017 at 12:34 AM
