Dim headlamp
130,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
JBEARJERRY
Dim headlamp on drivers side only.
Nov 24, 2017 at 9:17 AM
STEVE W.
  • 15,423 POSTS
Check the ground for the light and test the bulb as well. A bad ground will make the light try to ground out through the opposite filament.
Nov 24, 2017 at 10:03 AM
FREEMBA
  • 1,152 POSTS
In the under-hood fuse box, check the right hand HDLP (right hand headlight) fuse. Replace it if it is found to be faulty.
It is possible that you have a bad left side headlight (high-beam filament burned out) and a bad fuse for the right side headlight.
Thanks
Nov 24, 2017 at 10:07 AM
JBEARJERRY
Where is the location of the ground for the left side headlight ?
Nov 24, 2017 at 1:07 PM
STEVE W.
  • 15,423 POSTS
It is grounded through the DRL system. Here are the diagrams. I would check right at the light first.
Nov 24, 2017 at 4:19 PM
