Digital display quit working
120,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
SEAN PENROSE
The center cluster on the digital display just stopped working. No flickering or warnings. Just after sitting for a month, started the car and no center display. The two smaller displays on either side with fuel, range, and climate control work, and so does the display on/off switch.
Jun 29, 2019 at 6:35 AM
  • 55,711 POSTS
This is common when the cluster goes out and needs to be rebuilt. here is a video that shows the job being done on a similar car with diagrams below to show you on your car. We should check the fuses before you begin though.
https://youtu.be/_HEC44xENxw
Jul 1, 2019 at 5:21 AM
