The digital clock remains on when the ignition is shut off. I do not know if this is the way it is supposed to operate. Something has been draining the battery, and I am wondering if this is the cause. I have already replaced the battery, since it did not seem to want to hold a charge, not being sure if the digital clock is the problem. However, the new battery also drains, so I am starting to suspect that the clock is the problem. I have recharged the new battery and disconnected the cables until I can determine the source of the problem. Prior to disconnecting the battery cables, I did pull the fuse for the radio, but it had no effect on the digital clock. I do not know enough about the radio to know if that ought to have made any difference. My Haynes repair manuals do not give me any info on the digital clock. I hope you can answer this for me. I need to know if replacing the radio will solve the problem. Thank you.
May 30, 2013 at 10:06 AM
