Digital
1996 FORD FALCON
253,612 MILES
ANGRY MUM
My daughter has a el ford falcon gli 6 cyl
It's has digital mileage and trip meter 3 days ago all this was lost no fuel gauge speedo nothing plus the car won't change gears I changed the body control module as I was advised. But still nothing any sugestions ?
May 3, 2013 at 12:57 PM
HMAC300
  • 48,601 POSTS
we have no info on this car however, scan for codes asn it may be a speed sensor or the dash itself is bad. check all fuses including underhood and dash. it cold also be a governor or an internal trans problem bcm doesNOT control trans or engine so was a waste of money.
May 4, 2013 at 1:04 AM
JAGGERJACK06
  • 14 POSTS
i take it it is a manual? it is quite possible your cluster is kaput. the speedometer is operated by a signal of output speed by the transaxle, but, if your fuel gauge is also not working as this isa completely different system i would say the problem lies in the cluster. Possibly try and get your hands on a good second hand one (maybe from wreckers) and try it first, if this resolves the issue, then happy sailing. If not please advise of results
May 22, 2013 at 12:24 PM
