Difficult steering in one direction
200,275 MILES • 2.8L • V6 • 2WD • AUTOMATIC
ETERNALARIANNE
  • 244 POSTS
The steering on my car got very difficult to turn anything more than 45 degrees in both directions (I pulled a muscle in my chest doing a hard turn a few times). I replaced the power steering pump and it’s worlds better, especially on hard left turns. But hard right turns are still a bit difficult (although not muscle pulling difficult).
It’s like it will be difficult up to a certain point, then it will “break free” on the last bit of the hard right turn. If I turn it all the way right then go back left it’s very easy, it’s like it’s only hard going to the right and not going back the other direction.
Jan 25, 2021 at 7:21 AM
  • 110,251 POSTS
I have to be honest. It sounds like the rack and pinion steering gear is bad. Does it do it all the time? Is it something that is affected by temperature or doesn't that matter? Does it change after being driven?
Jan 25, 2021 at 11:56 AM
ETERNALARIANNE
  • 244 POSTS
It is easier at faster speeds, and I think it may be getting better the more I drive it. My neighbor (who used to be a mechanic) seems to think that since the car sat for a few years before I got it, that it may just need to be “worked in”. That and it’s just “old”.
I haven’t drove the car in really cold or really hot weather, only around 40-50F.
Jan 25, 2021 at 6:33 PM
  • 110,251 POSTS
It could be what your neighbor mentioned, but it shouldn't take too long for it to loosen. You replaced the pump. Is the new fluid you installed still clean and in good condition. If it looks dirty, you may want to flush the system. Here is a link that shows how it's done:
https://www.2carpros.com/articles/power-steering-fluid-flush
Jan 26, 2021 at 7:07 AM
ETERNALARIANNE
  • 244 POSTS
The fluid looks about the same as it did when we filled it up. If it doesn’t get much better with more driving, I’ll flush the system just to be safe.
Jan 26, 2021 at 7:10 AM
  • 110,251 POSTS
That sounds like a good idea. If you could, please let me know the outcome. I'm interested in knowing.
I hope the rack and pinion is good. I remember years back, there were bushings that would fail and then they would bind. If you look where the inner tie rod goes into the rack (at the boot on each side), see if there is any evidence of fluid. You may have to gently pry the boot open to confirm.
I attached a pic of the rack and highlighted where to check.
Jan 26, 2021 at 7:24 AM
ETERNALARIANNE
  • 244 POSTS
I’ve driven it some more, I think it’s about as good as it’s going to get for now. Right turns are a bit tight still but it breaks loose eventually, left turns now hit a “bump” sometimes and have to break loose as well but not all the time going left.
What’s weird is that I was backing up to the right and it was smooth as ever, then turning back left was hard. Go figure.
Haven’t had a chance to check those deals due to rain, but I’m thinking the rack may be going out as you suggested, unless you can think of anything else.
Jan 29, 2021 at 2:59 AM
  • 110,251 POSTS
I have to be honest. I really feel the rack and pinion is bad. If you decide to replace it, here are the directions. Also, if you check places like Rockauto.com, you may find it isn't an expensive part.
The attached pics correlate with the directions.
_____________________________________________
1987 Chevrolet Celebrity V6-173 2.8L
Removal and Installation
Vehicle Steering and Suspension Steering Steering Gear Service and Repair Procedures Removal and Installation Power Rack and Pinion Assembly Removal and Installation
REMOVAL AND INSTALLATION
RACK AND PINION ASSEMBLY REMOVAL
TOOL REQUIRED:
^ J 24319-01 Puller
Rack And Pinion Mounting
pic 1
Power Steering Line Routing - V6
pic 2
REMOVE OR DISCONNECT
1. Air cleaner.
2. Intermediate shaft lower pinch bolt.
3. Intermediate shaft from stub shaft.
CAUTION: Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or intermediate shaft. This damage can cause loss of steering control which could result in personal injury.
4. Line retaining clips.
5. Lines at gear from pump.
6. Raise car with suspension contact hoist.
7. Both front tire and wheel assemblies.
8. Tie rod ends from knuckles with J 24319-01.
9. Remaining brackets and clips on cross member.
10. Support body with stands to allow lowering of frame.
11. Rear frame mount bolts and lower rear of frame up to 128 mm (5").
NOTICE: Do not lower rear of frame too far as damage to engine components nearest to the cowl may result.
12. Heat shield (if equipped).
13. Rack and pinion mounting bolts.
14. Rack and pinion through left wheel opening.
INSTALL OR CONNECT
1. Rack and pinion through left wheel opening.
2. Rack and pinion mounting bolts.
TIGHTEN
^ Torque rack and pinion mounting bolts to 95 Nm (70 lbs. ft.).
3. Heat shield (if equipped).
4. Raise frame and install rear frame bolts.
5. Remove stands.
6. Brackets and clips on cross member.
7. Tie rod ends.
TIGHTEN
^ Tighten tie rod ends to 40 Nm (30 lbs. ft.), 70 Nm (52 lbs. ft.) max. to install cotter pin.
8. Both tire and wheel assemblies.
9. Lower car.
10. Lines at gear from pump.
TIGHTEN
^ Lines at gear pump to 25 Nm (18 lbs. ft.).
11. Line retaining clips.
12. Intermediate shaft at stub shaft and tighten pinch bolt.
13. Air cleaner.
14. Fill with fluid.
15. Bleed air from system.
INSPECT
^ For leaks. If leak is found, correct cause of leak and bleed system.
______________________________________________________
Let me know if there is anything I can do to help.
Jan 29, 2021 at 11:51 AM
