Differential fluid level check?
210,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
RDANNENFELSER
  • 43 POSTS
When checking the level of differential fluid in a rear axle, should the fluid be checked warm after the vehicle has been driven or should it be checked cold?
Mar 16, 2020 at 4:51 PM
SCGRANTURISMO
  • 4,897 POSTS
In the diagrams down below I have included the operating specs for your vehicle's rear differential including the cold capacity and fluid type. I hope this helps.
Thanks,
Alex
2CarPros
Jun 7, 2021 at 5:47 AM
RDANNENFELSER
  • 43 POSTS
To be honest, no, the images don't help. They provide info on the fluid capacity, features, specs, and parts of the rear axle, but I'm just wanting to know if the gear oil inside the differential should be at warm operating temperatue or cold ambient air temperature when checking the fluid level.
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Actually, the lack of the instructions to say to measure it warm indicates that it should be measured cold.
Thanks,
Alex
2CarPros
RDANNENFELSER
  • 43 POSTS
