differential
2008 SUBARU IMPREZA
106,000 MILES • 2.5L • 4 CYL • AWD • MANUAL
JOSEPH PASKVAN
My car gives off a loud thumping sound when taking sharp turns. I was told it was due to a binding differential. If that is the case would this also cause the need to replace the transmission?
Aug 13, 2016 at 2:45 AM
  • 31,937 POSTS
This can be the wrong oil in the final drive has any work been preformed recently, i would also drain the diff oil and inspect for metal fragments, if there is silver specks in the oil this will be bearing or tooth metal and a sign of serious wear.
Aug 13, 2016 at 9:28 PM
