Differential output shafts removal
1992 NISSAN 240SX
150,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
ZACHSHAW.329
I am trying to remove my differential output shafts. One of them popped out easily but the other one will not budge at all. I have tried soaking it in pb blaster to see if that helps but nothing will break it loose.
Jan 4, 2021 at 5:23 AM
Good evening,
Which end is seized? The part into the differential or the end at the hub?
The better lube is Freeze Off. PB does not break down rust.
Jan 4, 2021 at 8:25 AM
ZACHSHAW.329
It is the part that goes into the differential?
Jan 4, 2021 at 10:20 AM
The clip is not releasing. There is a tool for removing it that is like a fork with a slide hammer on it. Sometimes those clips do not want to release.
https://www.2carpros.com/articles/replace-cv-axle
Check at a parts store for the tool.
Jan 4, 2021 at 7:01 PM
