difficult to shift
150,000 MILES • 1.5L • 4 CYL • 2WD • MANUAL
PAKRAT53
clutch not slipping but will not shift into first or reverse without shutting off engine.
May 3, 2017 at 5:26 AM
HMAC300
  • 48,601 POSTS
sounds like a bad clutch or hydraulics are not working if you have hydraulic clutch. may be a bent fork, or throw out bearing going through pressure plate.
May 3, 2017 at 6:04 AM
PAKRAT53
that is what i was afraid of, worn pressure plate throw out bearing. thank you that helps a lot.
May 3, 2017 at 8:34 AM
  • 55,770 POSTS
Please let us know what you find ;)
Cheers, Ken
May 5, 2017 at 9:57 AM
