Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Tercel
Drivetrain
Differential
Gear Oil
Differential fluid
1989 TOYOTA TERCEL
95,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
TOM ELLIS
MEMBER
1 POST
What fluid do i use in the car listed above it is front wheel drive? I have been told to use the same ATF i put in the transmission.
Nov 1, 2017 at 4:53 AM
PATENTED_REPAIR_PRO
Experienced Mechanic
Isn't this a front wheel drive and has a trans-axle? The transmission and differential is a trans-axle and it takes DEXRON II ATF.
Nov 1, 2017 at 5:59 AM
KHLOW2008
Depending on which transmission you have and if it is the one with a separate differential, the recommended is SAE 90, but many I have seen uses ATF.
Nov 2, 2017 at 1:06 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
