Dieseling EFI engine
CLEE01
I have a similar dieseling problem on a RAV4 2003 model that has done 280,000km. I also have a 'hard to start' problem. I have changed worn spark plugs, used high octane fuel, replaced the fuel filter, clean the injectors, check battery and start motor. I am left with fuel pump and regulator. Could the pump and regulator contribute to dieseling?
Tuesday, July 23rd, 2019 AT 6:59 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,217 POSTS
Not really, I would try cleaning the throttle bore first, also is there any codes here are two guides that will help us fix the problem.
and
Tuesday, July 23rd, 2019 AT 1:06 PM
CLEE01
Hi Ken, I typed my respond in 'Was this answer helpful?'. Hope you can view it.
Wednesday, July 31st, 2019 AT 6:14 AM
KEN L
  • 54,217 POSTS
Hmm, I don't see it. Can you re-post in the correct reply box? That box is for visitors to the page that are not involved with the problem. We are making changed to clarify the issue.
Wednesday, July 31st, 2019 AT 11:57 AM
