After the lift pump was replaced, I was able to drive another 35 km, after which the engine just stopped. Injection pump DS 4 renewed, diesel filter renewed, new hoses from filter to DS 4 replaced. The lift pump presses in the diesel properly, and the return flow is free of air bubbles. New PMD replaced. What else can it be? Solenoid valve on the pump with 12 volts is there. The cable from the optocoupler to the electronics is measured. Available on PMD 5 volt and 12 volt. Winnebago Brave P 30 Motortyp F GM 6.5 Turbo diesel
Jun 18, 2022 at 11:08 PM
