Once you have replaced the injectors on the 2.0 diesel engine you will need to program the injector (IMA) codes into the ECM using a suitable diagnostic tool.
The injector code is a 20-digit code located on top of the injectors but it should also be supplied on a separate information sheet
You will also have to reset the zero fuel correction (ZFC).
When installing new injectors do not reuse the washers and fuel supply pipes.
Fit new.
A video showing procedure:
https://youtu.be/rYkzkKHUDeQ?si=21YHt7nq0Nlw_sTH
Cheers, Boris
Jan 3, 2024 at 5:38 PM
