Shuts off while driving, only when warmed up
150,000 MILES • 4.6L • V8 • 2WD • MANUAL
STEPHEN BREWER JR.
  • 7 POSTS
Car listed above is a GT. Shuts off once warmed up then won't fire. Sputters a little. New fuel pump because shop said the readings were off when car warmed up ($1,000.00). Next day same symptoms and towed back to shop. New air idle control seemed to help for awhile but now it dies Every time it warms up. No codes. Please help . Much appreciated!
Sep 22, 2019 at 4:52 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Since it is happening when it is warm, my first suspect is a bad crankshaft position sensor. When they start going bad, they tend to fail when they get hot. When it won't start, check to see if there is spark to the plugs. I suspect there isn't. Or you can use a live data scanner to see if there is an rpm signal.
Take a look through these links. The first one explains what the sensor does, the second symptoms, and the third shows in general how one is replaced.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Let me know if the symptoms indicated seem to mirror what you are experiencing. I will then better know the best way to direct you.
Sep 22, 2019 at 10:55 AM
STEPHEN BREWER JR.
  • 7 POSTS
Thanks Joe, the shop still has it . Would a established shop be able to diagnose this do you think? If they don't have a clue by tomorrow I'm bringing it home .They already charged me$1000 for a fuel pump they thought was the problem.
Sep 22, 2019 at 12:51 PM
  • 110,248 POSTS
Welcome back:
I would think they should be able. That is one of the most common causes if the symptoms you described. Wow! A grand for a fuel pump? That's a lot.
It's easy to check. If there is no RPM signal when it fails to start (using a live data scanner) or spark is lost to the plugs will tell the story. Interestingly, under certain conditions a bad sensor will not set a diagnostic trouble code, so that confuses people.
Feel free to let me know if you have questions or need help. I can walk you through the testing process if needed and you can do it yourself.
In case you want to check it yourself, chances are you don't have the live data scanner, so here is a link that explains how to check for spark.
You can do it that way or when it refuses to start, see if starting fluid makes a difference. If it doesn't even start for a couple seconds using starting fluid, there is no ignition spark.
Also, when it refuses to start, see if you can hear the fuel pump prime when you first turn the key on.
Take care and let me know what happens.
Sep 22, 2019 at 1:38 PM
STEPHEN BREWER JR.
  • 7 POSTS
$600.00 more for some random things and I guess a messed up wire.
Sep 23, 2019 at 7:47 AM
  • 110,248 POSTS
Welcome back:
I can't read the pic. What was done? What parts and which wire?
Sep 23, 2019 at 1:11 PM
STEPHEN BREWER JR.
  • 7 POSTS
Fuel pump driver module, oil pressure switch, fuel rail pressure sensor was reading 90 psi and should be reading 45-50 psi. Fixed chaff wires to idle air control and twisted wires at fuel rail pressure sensor.
Sep 23, 2019 at 10:31 PM
  • 110,248 POSTS
Thanks for letting me know. The fuel pressure was certainly the problem.
Let us know if we can help in the future.
Sep 24, 2019 at 10:15 AM
