Stalls when put into gear?
160,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
AMANDA HOGGARD STEARNS
Over oiled the air filters (lifetime ones). overheated and popped a radiator hose, made it home harmonic balancer went out. Replaced it, the MAP sensor, neutral safety switch and thermostat. She starts and idles just fine (check engine light is not on, and transmission fluid is not burnt and is still red), but when you put it into gear it shuts off. Help!
Feb 28, 2018 at 10:08 AM
Good morning,
If it stalls in all gears, it may be the torque converter that is locked up causing the stalling.
https://www.2carpros.com/articles/stall-at-idle
Before assuming that, I would clean the throttle body of all carbon deposits. I attached a guide for you to follow.
Jul 2, 2021 at 11:49 PM
