Engine shuts off when put into gear
202,500 MILES • 5.7L • V8 • 4WD • AUTOMATIC
TBIEDERMAN5
  • 14 POSTS
It will turn over and start most the time and it will idle but when you rev it up it hesitates but stays running. If you turn the wheel and shift it into any gear but neutral it shuts off right away. No codes the last time I checked before this happen. It would lock and unlock randomly while driving then shut off while driving. I put a different battery in it it started up and I drove it home then it was doing the above problem.
Jul 17, 2018 at 9:19 AM
TBIEDERMAN5
  • 14 POSTS
Ran codes nothing came up. This is the ready test results.
Jul 18, 2018 at 9:32 AM
TBIEDERMAN5
  • 14 POSTS
Also noticed these two ground cables hanging loose.
Jul 18, 2018 at 9:33 AM
  • 55,766 POSTS
Those ground wires can be causing all of your electrical problems they need to be connected. Where is the other side of the cable? Clean the cable connections before installing them. Clear the codes and try again.
Please let us know what you find.
Cheers, Ken
Jul 18, 2018 at 11:49 AM
TBIEDERMAN5
  • 14 POSTS
The one goes to the frame the other one goes to the engine. It looks like and they perfectly reach each other should I connect them together?
Jul 19, 2018 at 9:47 AM
  • 55,766 POSTS
The large one goes to the engine and the small one goes to the frame/body. Can you take pictures of the other end so I can see to be sure?
Jul 20, 2018 at 3:16 AM
TBIEDERMAN5
  • 14 POSTS
That is where the small one goes.
Jul 20, 2018 at 9:53 AM
TBIEDERMAN5
  • 14 POSTS
The large one goes into that tube towards the engine.
Jul 20, 2018 at 9:54 AM
TBIEDERMAN5
  • 14 POSTS
Also the large one.
Jul 20, 2018 at 9:57 AM
TBIEDERMAN5
  • 14 POSTS
Also noticed this was wet with oily liquid.
Jul 20, 2018 at 9:58 AM
STEVE W.
  • 15,418 POSTS
Those are both grounds. One should go from the frame to the engine, the other goes from the engine to the body. In this case you have the middle point where both of those attach to the frame. Does not really matter where you attach them as long as it is a clean connection with no paint or rust and they can flex as the engine and body move around. Does not matter if the braid is oily, as long as the rings are clean where they meet the other parts.
With them loose as they are you will get many strange electrical issues as well as possible parts failures in what seem to be unrelated parts. This is due to the currant from the battery seeking to find a path to complete the circuit back to the battery or from the alternator though its circuit paths.
From the first picture they were either both bolted under the cable clamp or in the hole to the left. Either will work as long as you clean the rings on the braids and the spot on the frame.
Jul 20, 2018 at 10:21 AM
TBIEDERMAN5
  • 14 POSTS
Okay, I will do that. Thank you both very much. I will let you know if it works.
Jul 20, 2018 at 10:55 AM
TBIEDERMAN5
  • 14 POSTS
Got them connected fixed all my problems. Thank you very much.
Jul 21, 2018 at 4:58 AM
  • 55,766 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Jul 21, 2018 at 5:58 AM
STEVE W.
  • 15,418 POSTS
Great to hear you solved the problem. One of the mantras an old gentleman I knew always said when presented with an electrical problem - "Check the Grounds". These days it is even worse due to all the electronics on the vehicles.
Jul 21, 2018 at 11:16 AM
