Dies when not given gas?
158,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
WHOPPEY
I'm trying to help a friend who recently got screwed over by a very expensive "mechanic". The main problem he's having is the car idles kinda rough and it dies whenever he lets off the gas at red lights, stop signs, etc. I was thinking a dirty idle air control valve or throttle body. I checked for vacuum leaks and everything was good there. Its got newer sparkplugs and wires from previous mechanic.
Aug 29, 2025 at 6:15 AM
  • 55,658 POSTS
So we need to check the engine compression which will cause this kind of issue. Also, you must make sure the correct spark plugs were installed. Here is a guide to help with the testing
These are the spark plugs that need to be installed.
ACDelco 41-101 (Professional Iridium) - this is the OEM plug GM spec’d for that engine.
Gap: 0.040 in (1.0 mm)
Please upload what the spark plugs look like so I can see them to tell what might be happening as well when you get back to us.
Aug 29, 2025 at 11:05 AM
