Shuts off when i put it in gear
346,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
UNCLEBIFF
  • 37 POSTS
My car starts right up, idles just fine but shuts off when i put it in gear.
Mar 16, 2018 at 12:17 PM
MIKE H R
  • 3,094 POSTS
Check and see if you are getting power to the neutral safety switch. works similar to a neutral safety switch in a standard shift car. also, check the wires under the car and make sure they are tight and clean. This may or may not hep but it is a good place to start.
Mar 17, 2018 at 12:31 AM
