Shuts off at will without warning
168,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
IWONDER
I just acquired the van listed above (Grand Caravan 3.3-R engine). The test drive went flawless. Then once home I took it to a parts store that I trust for the check engine light and he said that there was an error message and that he could not even begin to retrieve the trouble codes.
On the way home it shut off several times and would take five to fifteen minutes before restarting and then might run for five minutes or twenty seconds.
I have been told that it was the PCM, but with limited diagnostic flow chart and pinpoint test information I am skeptical without verifying it through proper checkout and diagnostic tests.
I had a stroke several years ago and do not have all of the testing equipment and information, ie Mitchell/ AllData Snap On scanner that I used to have at my shop.
This is why I am having to reach out to you for assistance.
Feb 7, 2018 at 10:58 AM
CARADIODOC
  • 34,414 POSTS
There are two common things to start with. The first is a failing crankshaft position sensor or camshaft position sensor. These commonly fail on any brand of engine by becoming heat-sensitive, then they work again after cooling down for about an hour. This usually occurs right after stopping a hot engine for a short period of time, as in when stopping for gas. While driving, natural air flow keeps the sensors cool. When stopped, "hot soak" allows engine heat to migrate up to the sensors and causes them to fail.
The problem with this is if you only have the crank/no-start problem, diagnostic fault codes might not set for those sensors. They often need more time, as in when a stalled engine is coasting to a stop. You do not need a scanner to read fault codes in the engine computer. Chrysler made doing that yourself much easier than any other manufacturer. Cycle the ignition switch from "off" to "run" three times within five seconds, leave it in "run", then watch the code numbers show up in the odometer display.
When there are no fault codes related to the crank/no-start, we will need to determine if the automatic shutdown, (ASD) relay is turning on during cranking. I will describe how to check for that if it becomes necessary. You will need a test light to measure the voltage at the ignition coil pack or any injector. Look for the wire that is the same color at all of those places. It iss usually dark green/orange. If either sensor has failed, this relay will turn on for one second when you turn on the ignition switch, but it will not turn back on during cranking. That relay feeds the ignition coil pack, injectors, alternator field, fuel pump or pump relay, and oxygen sensor heaters, so if it does not turn on, you will have a crank/no-start due to no spark, no injector pulses, and no fuel pump.
Since this occurs while you are driving, the better suspect is broken solder connections on the connector for the instrument cluster. Pounding on the top of the dash is not a scientific approach, but I just repaired one for this problem a few months ago, and that owner had kept the van going by doing that for over a year. I cannot remember if the starter would crank the engine, but if it did, it definitely would not start and run. As I recall, there were additional clues in that some of the warning lights were on or failed to turn on.
Feb 7, 2018 at 11:18 AM
IWONDER
All of the indicator lights are functioning correctly. My initial problem is, with three different code readers, there is no information to even identify what vehicle it is. All of the scanners only showed an error message and nothing else.
Feb 7, 2018 at 11:44 AM
IWONDER
I Previously stated that my engine was a 3.3-R. when in fact it is a 3.3-3 V6.
Feb 8, 2018 at 6:31 AM (Merged)
CARADIODOC
  • 34,414 POSTS
Feb 8, 2018 at 9:45 AM
