Engine shuts off while idling
230,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
NEWKIRK TYE
Car is hard starting and shuts off at idle. Drives fine but as soon as I get out of gear to idle it just shuts off immediately.
Mar 15, 2022 at 11:57 AM
  • 110,248 POSTS
Have you checked to see if there is an engine vacuum leak? That can cause a stalling issue. Also, in 1989, these vehicles were made with either a carburetor or fuel injection. Which does the vehicle have?
Start with checking for vacuum leaks. Here is a link that explains how it's done:
Also, if possible, record what it does so I can see and hear what it does. That may help me as well.
One more thing, take a look at this link. Id reviews the most common causes of a stalling issue at idle and how to fix one.
https://www.2carpros.com/articles/stall-at-idle
Mar 16, 2022 at 11:12 AM
NEWKIRK TYE
Thank you for the help. It is fuel injected. The air filter was pretty clogged but I’m not sure if it helped yet. I haven’t taken a ride yet. I will do so tomorrow and take a video for you. I will go through the link as well and see what I can learn there. Again, thank you for the reply.
Mar 16, 2022 at 1:07 PM
  • 110,248 POSTS
If there was an air restriction, it could be the cause. It will cause the engine to run too rich.
Let me know if that has helped or not.
Take care and let me know what I can do to help.
Mar 16, 2022 at 1:33 PM
