Shuts off after starting
241,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BECSAM
Yesterday I changed the fuel pump. Ran fine all day. I am an Uber driver so I drove for five hours and about 160 miles after changing fuel pump. Last night I went to warm up the car to go to store, I live in Massachusetts so is cold out side. I started the car like I have done many times before, started walking away to go inside and it shut off. Started again, after a minute, Shut off again, no rough idle, just quit running. Never done this before, always ran great. Please any suggestions?
Jan 12, 2019 at 8:54 PM
  • 110,248 POSTS
Since you replaced the pump, I would suggest checking to make sure fuel pressure is within the manufacturer's specs. Also, if the fuel filter wasn't replaced, consider doing it.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
____________________________
Here are directions specific to checking pressure on your vehicle. The directions include pressure specifications and diagnostic aids.
COMPONENT TESTS AND GENERAL DIAGNOSTICS
FUEL DELIVERY SYSTEM
Fuel Pressure Test
1. PREPARING
1. Open the service cover under the floor carpet.
2. RELEASE THE INTERNAL PRESSURE
1. Disconnect the fuel pump connector.
2. Start the engine and wait until fuel in fuel line is exhausted.
3. After the engine stalls, turn the ignition switch to OFF position and disconnect the negative (-) terminal from the battery.
Note: Be sure to reduce the fuel pressure before disconnecting the fuel feed hose, otherwise fuel will spill out
Fuel Pressure Special Service Tool
See picture 1
3. INSTALL THE SPECIAL SERVICE TOOL (SST) FOR MEASURING THE FUEL PRESSURE
1. Disconnect the fuel feed hose from the delivery pipe.
Caution: Cover the hose connection with a shop towel to prevent splashing of fuel caused by residual pressure in the fuel line.
2. Install the Fuel Pressure Gage Adapter (09353-38000) between the delivery pipe and the fuel feed hose.
3. Connect the Fuel Pressure Gage Connector (09353-24000) to the Fuel Pressure Gage Adapter (09353-38000).
4. Connect the Fuel Pressure Gage and Hose (09353~41 00) to Fuel Pressure Gage Connector (09353-24000).
5. Connect the fuel feed hose to the Fuel Pressure Gage Adapter (09353-38000).
4. INSPECT FUEL LEAKAGE ON CONNECTION
1. Connect the battery negative (-) terminal.
2. Apply battery voltage to the fuel pump terminal and activate the fuel pump. With fuel pressure applied, check that there is no fuel leakage from the fuel pressure gauge or connection part.
5. FUEL PRESSURE TEST
1. Disconnect the negative (-) terminal from the battery.
2. Connect the fuel pump connector.
3. Connect the battery negative (-) terminal.
4. Start the engine and measure the fuel pressure at idle.
Standard Value: 343 Kpa (3.5 kgf/cm cm, 49.8 psi)
Incorrect Pressure
See picture 2
If the measured fuel pressure differs from the standard value, perform the necessary repairs using the table below.
Pressure Drops
See picture
5. Stop the engine and check for a change in the fuel pressure gauge reading.
After engine stops, the gage reading should hold for about 5 minutes
Observing the declination of the fuel pressure when the gage reading drops and perform the necessary repairs using the table below.
6. RELEASE THE INTERNAL PRESSURE
Note: Be sure to reduce the fuel pressure before disconnecting the fuel feed hose, otherwise fuel will spill out.
7. REMOVE THE SPECIAL SERVICE TOOL (SST) AND CONNECT THE FUEL LINE
1. Disconnect the Fuel Pressure Gage and Hose (09353-24100) from the Fuel Pressure Gage Connector (09353-24000).
2. Disconnect the Fuel Pressure Gage Connector (09353-24000) from the Fuel Pressure Gage Adapter (09353-38000).
3. Disconnect the fuel feed hose from the Fuel Pressure Gage Adapter (09353-38000).
4. Disconnect the Fuel Pressure Gage Adapter (09353-38000) from the delivery pipe.
5. Connect the fuel feed hose to the delivery pipe.
8. INSPECT FUEL LEAKAGE ON CONNECTION
3. If the vehicle is normal, connect the fuel pump connector.
____________________________________________________
If pressure is within the manufacturer's specs, then I suspect a bad crankshaft position sensor. Take a look through this link:
Here is a link that shows in general how this sensor is replaced:
Picture 4 shows the crankshaft position sensor's location. You need to remove the timing belt cover to replace it.
Let me know if this helps.
Jan 13, 2019 at 3:20 AM
BECSAM
Hi Joe, thank you for replying. Two points, no codes detected and no check engine light, plus could not reproduce today after setting all night. Only shut off once this morning. Not shutting off while driving, just seems at cold idle yesterday. Never did it before yesterday.
Jan 13, 2019 at 3:35 AM
  • 110,248 POSTS
Because of the way a crank sensor works, it may or may not set a code. So, keep an eye on that. If the vehicle ran good once warmed up, it could be a few things such as a faulty idle air control valve, coolant temperature sensor and so on. If it continues, let me know. Also, let me know if you have access to a live data scanner.
Jan 13, 2019 at 3:52 AM
BECSAM
Hi again. I tried to reproduce what happened last night. Waited four hours and the car is really cold. Just went out now and started the car and never tried to shut off. idled fine, warmed up normally like 1,000 times before last night. we are very stumped. Why can't I reproduce what happened last night if it is still cold out side? The car sat four hours just like last night. I got home yesterday at 3:30 pm, ran fine after changing fuel pump, went out at 7:30 pm and shut off every time, changed nothing, did nothing, yet today or won't shut off after starting.
Jan 13, 2019 at 3:56 AM
  • 110,248 POSTS
Welcome back:
I would let things alone then. There is a chance the computer was going through a relearn if you had the battery disconnected to replace the pump. However, if it happens again, let me know.
Jan 13, 2019 at 7:59 AM
BECSAM
Thank you Joe. I appreciate the help and advice.
Jan 13, 2019 at 8:16 AM
  • 110,248 POSTS
Happy to help. Let me know if you need something.
Jan 13, 2019 at 12:18 PM
