Engine shuts off
185,000 MILES • 5.3L • 4WD • AUTOMATIC
ROGER42134
My son drove through water and it started shutting off. Will idle fine but give it gas it sputters and shuts off, with a smell of gas. Fuel pump makes a loud noise that stops after a few seconds.
Oct 4, 2018 at 2:38 AM
Good morning.
It definitely sounds like you need to replace the fuel pump. It should never make any noise. Good chance water got in the tank and that has caused the issue.
I would also look into draining the tank and cleaning it out.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Oct 4, 2018 at 2:56 AM
