Shut off while driving?
2,000 MILES
JASONFAIRCHILD
My car turns over but it’s acting like it’s getting no fuel to the engine. I can hear my fuel pump start when I turn the key, but it won’t fire, I checked my relay. What else could it be?
Nov 19, 2022 at 12:18 PM
  • 110,244 POSTS
When you have a crank with no start condition, it usually is the result of either a fuel-related or ignition-related issue.
Take a look at this link:
https://www.2carpros.com/articles/car-not-running-advanced
Here is what I want you to try: See if the engine starts using starting fluid. If it does and then stalls, we will know it's a fuel-related issue. If there is no change, then I need you to check for spark to the plugs.
Here is a link that explains how to check for spark:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Start with this and let me know the results.
Nov 19, 2022 at 2:29 PM
