Engine shut off coming down road
160,250 MILES • 5.7L • V8 • 4WD • AUTOMATIC
BUSTER1
It will start only by holding down on throttle, but will shut off if you take foot off.
May 31, 2019 at 8:57 PM
Good morning,
Is the check engine light on? If it is, do you know the code?
Some possibilities:
1. Fuel pressure.
2. Clogged catalytic converter.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
3. Low engine compression.
4. Engine timing.
All these need to be checked to determine the failure.
May 31, 2019 at 10:48 PM
