Diagram for connecting fuel hoses
200,000 MILES • 5.8L • V6 • 4WD • AUTOMATIC
CHRISTINA DAVIS
Oil pressure sending unit.
Mar 24, 2022 at 5:52 PM
Couple questions, you noted this was a 5.8L but it appears there was only a 4.8L or a 5.3L engine option, so which one is this vehicle?
Next you said you needed fuel line diagrams but where are you trying to connect them? To the pump? If so, I attached the info below, but the lines should be different sizes so that they only go on one connection.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Then you noted about the oil pressure sending unit. I attached the instructions on this unit, but I am just not sure if you need something different.
Please run through this info and let me know if you need more info. Thanks
Mar 26, 2022 at 3:07 AM
