Good morning.
Removal
1. Carry out the parking brake cable tension release.
2. Remove both rear wheels and tires.
imageZoom/Print
3. Disconnect the parking brake release actuator electrical connector.
imageZoom/Print
4. Detach the parking brake release actuator wiring harness retaining clip.
imageZoom/Print
5. Remove the parking brake release actuator retaining bolts.
imageZoom/Print
6. Detach the parking brake cable.
1. Reposition the retaining tang.
2. Detach the parking brake cable.
imageZoom/Print
7. Detach the parking brake release actuator cable.
imageZoom/Print
8. Detach the parking brake release actuator cable.
1. Release the retaining tangs.
2. Detach the parking brake release actuator cable.
imageZoom/Print
9. CAUTION: Place a suitable support stand under the axle assembly.
Remove the axle assembly retaining bolts.
imageZoom/Print
10. Lower the axle assembly.
imageZoom/Print
11. Remove the parking brake release actuator.
Images (Click to enlarge)
Aug 1, 2018 at 2:02 AM
